pertrl's avatar
pertrl
2 years ago
Schematic Symbol Parameter in Hex
how can I input a hexadecimal value in the parameter table of a block diagram/schematic file (.bdf)?
behind the block is the following VHDL code:
entity reg is
	generic (
		constant REG_BASE_ADDR : natural := 16#4010#;
	port (
end;
every variant I could imagine results in an error like:
Parameter     | Value   | Type
REG_BASE_ADDR | x"4010" | Auto
Error (10515): VHDL type mismatch error at reg.vhd(17): natural type does not match string literal
  • Hi,
    Done testing. Use the following for example:
    addr : std_logic_vector(15 downto 0) := x"FFFF"
    Then change line 16 from:
    signal reg : std_logic_vector(15 downto 0) := std_logic_vector(to_unsigned(addr, 16));
    to:
    signal reg : std_logic_vector(15 downto 0) := addr;
    You'll be able to use Hexadecimal type for example value AAAA
    Sheng
  • FvM's avatar
    FvM
    the problem doesn't seem related to VHDL support in my view. You can neither send a hexadecimal literal to a numerical Verilog module parameter. Only decimal numbers seem to be accepted as block parameters for numerical values.
  • pertrl's avatar
    pertrl
    I'm using Quartus Prime Lite 22.1.2 and 23.1
    With verilog it works for me like so:
    REG_BASE_ADDR | 4002  | Hexadecimal
    But something like X"4000" or 16#4000# is not a VHDL-2008 thing, or is it?
  • ShengN_altera's avatar
    ShengN_altera
    To input a hexadecimal value in the parameter table of a block diagram/schematic file (.bdf), set the (Type) to either Auto or Hexadecimal then under (Value) straight away give a value for example like: a, not need the symbol x""
    Sheng
    • pertrl's avatar
      pertrl
      This does not work. here is some test code:
      library ieee;
      use ieee.std_logic_1164.all;
      use ieee.numeric_std.all;
      entity test2 is
      	generic (
      		addr : natural := 16#4000#
      	port (
      		i_clk : in std_logic;
      		o	   : out std_logic_vector(15 downto 0)
      end;
      architecture arch of test2 is
      begin
      	o <= reg;
      end;
      generating a symbol from this code results in the following table:
      addr      | 16384 | Signed Integer
      and synthesizes correctly to
      using
      addr       | 4000  | Hexadecimal
      results in an error:
      Error (10515): VHDL type mismatch error at /asd.vhd(8): natural type does not match string literal
      using
      addr      | 4000  | Auto
      synthesizes incorrectly to:
    ShengN_altera
    May I know which block you're using in .bdf?
    Sheng
    • pertrl's avatar
      pertrl
      The one you get by clickling File -> Create/Update -> Create Symbole Files from Current File in the*.vhd file.
      the upper block with with Verilog works, VHDL does not.
    ShengN_altera
    to:
    Sheng
  • pertrl's avatar
    pertrl
    Not exactly the same, but it will do, thanks.
