pertrl
2 years agoSchematic Symbol Parameter in Hex
Hello, how can I input a hexadecimal value in the parameter table of a block diagram/schematic file (.bdf)? behind the block is the following VHDL code: entity reg is
generic (
constant REG_B...
- 2 years ago
Done testing. Use the following for example:
addr : std_logic_vector(15 downto 0) := x"FFFF"
Then change line 16 from:
signal reg : std_logic_vector(15 downto 0) := std_logic_vector(to_unsigned(addr, 16));
to:
signal reg : std_logic_vector(15 downto 0) := addr;
You'll be able to use Hexadecimal type for example value AAAA
Sheng
sstrell
2 years agoAssuming you are using Standard or Lite, you may be running into the limited VHDL 2008 support there: https://community.intel.com/t5/Programmable-Devices/Does-Quartus-20-1-std-support-VHDL-2008-vector-aggregation/m-p/1468730#M90058%3Fwapkw=Error%2010515
