12 years ago
Question on posedge in always block
I had something similar to the following code.
always @ (posedge a, posedge b)
begin
if(a)
begin
address <= address + 1;
end
else
begin
address <= 0;
end
end
'a' and 'b' are not clocks they are triggers. There is a separate clock that is used in separate state machines always blocks that run fine.
I was testing the code with signaltap and saw something that confused me.
Problem I was seeing is that address was incrementing on every clock cycle while ‘a’ was one ('b' was at zero) and not just when ‘a’ was transitioning from 0 to 1.
So with no posedges on either signal how could address be incrementing?
Thank you.....
    --- Quote Start ---
    begin
    if(a)
    begin
    end
    else
    begin
    address <= 0;
    end
    end
    Thank you.....
    --- Quote End ---
    based on my rusty verilog I think you should put the adder below rather than at top as (a) is meant to be reset while clock is (b)
    Does quartus complain about your code? If so, that is probably a hint as to why it is doing what it is doing.
    But as kaz suggested, if you restructure your code with the reset condition at the highest priority, and the adder at the lowest priority, it will probably work as you expect.
    See example 13-39 of the Recommended HDL Coding Styles:
    http://www.altera.com/literature/hb/qts/qts_qii51007.pdf
    --- Quote Start ---
    --- Quote End ---
    Time to learn a bit about required Verilog syntax for hardware synthesis. The always block structure in post# 1 has a well defined meaning for a Verilog compiler, which has been already mentioned by kaz. I agree that the usage of "event posedge a" for an asynchronous control input in this construct is somehow counter-intuitive, and may cause confusion if read literally. But the syntax is used by all synthesis tools and specified in ieee 1364.1 standard for verilog register transfer level synthesis.
    Besides understanding the required Verilog syntax, there are issues involved with the semantic of your code.
    - a FF can't be controlled by more than one edge sensitive input
    - using edge sensitive "triggers" other than the clock (s) in a design is against synchronous design rules and is likely to cause timing problems. In terms of timing analysis, any edge sensitive event will be recognized as clock
    In a strictly synchronous design, signal edges are detected by comparing previous and present state.
    Thanks for your replies.
    I have been winging it with verilog for a while now. Normally I stick to just using clock and reset in the sensitivity list (or just clock), however I was trying to copy a bit of Altera's code from their altsmi_parallel application note.
    always @ (posedge asmi_write_n, posedge reset_logic)
    begin
    if (reset_logic)
    flash_addr <= flash_start_add;
    else
    begin
    if (asmi_write_n)
    flash_addr <= flash_addr + 24'h000001;
    else
    flash_addr = flash_addr;
    end
    end
    I stuck the reset up front on my code and everything now works.
    I am still a bit confused about posedge though. i.e. Why does always block get triggered when there are no posedges?
    In what situation? In simulation it should not as it will go with whats in the sensitivity list. In synthesised code the sensitvity list is ignored and the logic is generated from the code.
    --- Quote Start ---
    --- Quote End ---
    I am a reletive noob even though I have been doing this for awhile. As I said I have been winging it and winging it rather impressively at that (I have been keeping things strictly synchronous).
    So.... if I am understanding you right simulated code may operate differently from synthesized logic?
    I suspect looking at the RTL may help in future if I run into this sort of thing again so I will take a look at that.....
    --- Quote Start ---
    --- Quote End ---
    Most likely because your 'a' signal is being connected to the reset (aclr) signal of the register, and that signal is not edge sensitive, it is level sensitive.
    Why would Quartus do such a thing? Because of what FvM wrote above.
    Quartus knew you didn't really want that, and gave you some messages to that effect (combinatorial loop and latches for your adder?).
    If you care to learn more first hand, reduce your code to it's most simplest case and study the Post-fit netlist for each case (broken vs. working) and you'll see how such a simple thing as the signal's relative priority can have drastic impact on what you get.
    begin
    if (reset_logic)
    else
    begin
    if (asmi_write_n)
    else
    end
    end
    According to what has been previously said about Verilog syntax for RTL synthesis, the code doesn't describe synchronous registers. Particularly flash_addr <= flash_addr + 24'h000001 is an asynchronous adder and won't work in synthesis. The question is if asmi_write_n should work as write enable in combination with a system clock or as a clock itself. flash_addr = flash_addr is superfluous in both cases.
    asmi_write_n is clock enable
    always @ (posedge clk, posedge reset_logic)
    begin
    if (reset_logic)
    else
    begin
    if (asmi_write_n)
    end
    end
    asmi_write_n is a clock
    begin
    if (reset_logic)
    else
    begin
    end
    end
    Final comment, if flash_start_add isn't a constant but a variable, the asynchronous preset function will be emulated by latches and additional logic because recent FPGA don't have an asynchronous register preset with their core registers. So it would be preferred to use a synchronous preset, if flash_start_add is a variable.
