12 years ago --- Quote Start --- I had something similar to the following code. always @ (posedge a, posedge b) begin if(a) begin address <= address + 1; end else begin address <= 0; end end 'a' and 'b' are not clocks they are triggers. There is a separate clock that is used in separate state machines always blocks that run fine. I was testing the code with signaltap and saw something that confused me. Problem I was seeing is that address was incrementing on every clock cycle while ‘a’ was one ('b' was at zero) and not just when ‘a’ was transitioning from 0 to 1. So with no posedges on either signal how could address be incrementing? Thank you..... --- Quote End --- based on my rusty verilog I think you should put the adder below rather than at top as (a) is meant to be reset while clock is (b)
