12 years agoThanks for your replies.
I have been winging it with verilog for a while now. Normally I stick to just using clock and reset in the sensitivity list (or just clock), however I was trying to copy a bit of Altera's code from their altsmi_parallel application note. always @ (posedge asmi_write_n, posedge reset_logic) begin if (reset_logic) flash_addr <= flash_start_add; else begin if (asmi_write_n) flash_addr <= flash_addr + 24'h000001; else flash_addr = flash_addr; end end I stuck the reset up front on my code and everything now works. I am still a bit confused about posedge though. i.e. Why does always block get triggered when there are no posedges?
