Altera_ForumHonored Contributor12 years agoQuestion on posedge in always block I had something similar to the following code. always @ (posedge a, posedge b) begin if(a) begin address <= address + 1; ...Show More
Recent DiscussionsMAX10 ADC - getting it to simulate in ModelsimFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verification
