jeffrs20's avatar
jeffrs20
2 years ago
Questa doesn't show UUT under Work
This is for Quartus Prime Standard and Questa Sim (both licensed).
Under the test bench, the instantiated UUT should be present. As I'm a novice I puzzled over what I was doing wrong. However, I started a scratch project using a tutorial and got the same results (YouTube, Rania Hussein, Tutorial). Aside from making syntax adjustments to use Verilog instead of System Verilog, I should have the identical results.
Question - why is the UUT (and therefore the variables in it) not present?
thank you.
  • When you generate a simulation script for an IP or an example design, it does.
  • sstrell's avatar
    sstrell
    Any screenshots? Code? Hard to figure out what's going on here without seeing anything you've done.
    • jeffrs20's avatar
      jeffrs20
      Hello. This is the simple tutorial source file. This compiles without issues. Attached is a screenshot of the Questa RTL sim, showing the testbench, but no DUT.
      Thank you.
      module fullAdder (A,B,cin,sum,cout);
      input A,B,cin;
      output sum, cout;
      assign sum = A ^ B ^ cin;
      assign cout = A & B | cin & (A ^ B);
      endmodule
      module fullAdder_testbench();
      reg A,B,cin;
      wire sum, cout;
      fullAdder dut (A, B, cin, sum, cout);
      initial begin
      A = 0; B = 0; cin = 0; #10;
      cin = 1; #10;
      B = 1; cin = 0; #10;
      cin = 1; #10;
      A = 1; B = 0; cin = 0; #10;
      cin = 1; #10;
      cin = 1; #10;
      $stop;
      end //initial
      endmodule
  • sstrell's avatar
    sstrell
    You say "compiles without issues," but do you mean in Quartus or in Questa? vsim only starts the simulator. You have to first compile your code in the Questa GUI or with the vlog command. You can generate a simulation script in Quartus that does this (Tools menu).
    • jeffrs20's avatar
      jeffrs20
      Quartus completes the compile. I attached a copy of the entire log but the final line is:
      Info (293000): Quartus Prime Full Compilation was successful. 0 errors, 18 warnings
      In Questa, here is a fresh RTL Sim called from Quartus. I attached the log file showing the tb was compiled.
  • sstrell's avatar
    sstrell
    Successful compilation in Quartus doesn't really matter for a simulation though it's still good to know it compiles successfully.
    Now that you've compiled in Questa and started the simulation, you have to add waveforms to the Wave view and then actually advance the simulation (run command).
  • jeffrs20's avatar
    jeffrs20
    Yes, I understand. But I expect the DUT to be listed between fullAdder_testbench and #INITIAL#18. I would select the DUT and the Objects would be listed, ready to be dragged into the Wave window. However, no DUT is present.
    Here is a screenshot of the YouTube tutorial. Note that unlike my project, the DUT is present.
  • sstrell's avatar
    sstrell
    In Questa, you have to add the +acc option so the command is
    vsim work.fullAdder_testbench -voptargs=+acc
    In the GUI, this is
    This is a change from Modelsim where this wasn't necessary.
    • jeffrs20's avatar
      jeffrs20
      I found this option. It looks slightly different than yours. But when I change to Apply full... The OK box is grayed out. I also looked inside Quartus to see if there is an option to pass this to the simulator but couldn't find anything applicable.
      • sstrell's avatar
        sstrell
        No, after compiling, do Simulate menu -> Start Simulation and click Simulation Options. You also have to select the top-level design unit on the Design tab there.
  • jeffrs20's avatar
    jeffrs20
    Ah. That worked! But why doesn't Quartus have an option to pass this option directly to Questa?
  • sstrell's avatar
    sstrell
