jeffrs20
2 years agoQuesta doesn't show UUT under Work
This is for Quartus Prime Standard and Questa Sim (both licensed). Under the test bench, the instantiated UUT should be present. As I'm a novice I puzzled over what I was doing wrong. However, I s...
- 2 years ago
When you generate a simulation script for an IP or an example design, it does.
jeffrs20
2 years agoThank you very much!
Jeff
