jeffrs20
2 years agoQuesta doesn't show UUT under Work
This is for Quartus Prime Standard and Questa Sim (both licensed). Under the test bench, the instantiated UUT should be present. As I'm a novice I puzzled over what I was doing wrong. However, I s...
- 2 years ago
When you generate a simulation script for an IP or an example design, it does.
sstrell
2 years agoAny screenshots? Code? Hard to figure out what's going on here without seeing anything you've done.
- jeffrs202 years ago
Hello. This is the simple tutorial source file. This compiles without issues. Attached is a screenshot of the Questa RTL sim, showing the testbench, but no DUT.
Thank you.module fullAdder (A,B,cin,sum,cout);input A,B,cin;output sum, cout;assign sum = A ^ B ^ cin;assign cout = A & B | cin & (A ^ B);endmodulemodule fullAdder_testbench();reg A,B,cin;wire sum, cout;fullAdder dut (A, B, cin, sum, cout);initial beginA = 0; B = 0; cin = 0; #10;cin = 1; #10;B = 1; cin = 0; #10;cin = 1; #10;A = 1; B = 0; cin = 0; #10;cin = 1; #10;B = 1; cin = 0; #10;cin = 1; #10;$stop;end //initialendmodule
