jeffrs20
2 years agoQuesta doesn't show UUT under Work
This is for Quartus Prime Standard and Questa Sim (both licensed). Under the test bench, the instantiated UUT should be present. As I'm a novice I puzzled over what I was doing wrong. However, I s...
- 2 years ago
When you generate a simulation script for an IP or an example design, it does.
jeffrs20
2 years agoYes, I understand. But I expect the DUT to be listed between fullAdder_testbench and #INITIAL#18. I would select the DUT and the Objects would be listed, ready to be dragged into the Wave window. However, no DUT is present.
Here is a screenshot of the YouTube tutorial. Note that unlike my project, the DUT is present.
