jeffrs20
2 years agoQuesta doesn't show UUT under Work
This is for Quartus Prime Standard and Questa Sim (both licensed). Under the test bench, the instantiated UUT should be present. As I'm a novice I puzzled over what I was doing wrong. However, I s...
- 2 years ago
When you generate a simulation script for an IP or an example design, it does.
sstrell
2 years agoSuccessful compilation in Quartus doesn't really matter for a simulation though it's still good to know it compiles successfully.
Now that you've compiled in Questa and started the simulation, you have to add waveforms to the Wave view and then actually advance the simulation (run command).
