10 years agoQuartus complaint: My LOOP is too big? But the code is from the book, what's wrong?
Hello friends. I'm trying to make addition and subtraction of floating point. My guide is a book "Computer Arithmetic and Verilog HDL Fundamentals" by Cavanagh. Inside the module he use a code for aligning exponents as I show as follows.
always @ (oper_1 or oper_2) begin exp_a = oper_1 [31:24]; exp_b = oper_2 [31:24]; fract_a = oper_1 [23:0]; fract_b = oper_2 [23:0]; // bias exponents exp_a_bias = exp_a + 8'b0111_1111; exp_b_bias = exp_b + 8'b0111_1111; // align fractions if (exp_a_bias < exp_b_bias) ctrl_align = exp_b_bias - exp_a_bias; while (ctrl_align) begin fract_a = fract_a >> 1; exp_a_bias = exp_a_bias + 1; ctrl_align = ctrl_align - 1; end if (exp_b_bias < exp_a_bias) ctrl_align = exp_a_bias - exp_b_bias; while (ctrl_align) begin fract_b = fract_b >> 1; exp_b_bias = exp_b_bias + 1; ctrl_align = ctrl_align - 1; end Quartus II give me the following error: Error (10119): Verilog HDL Loop Statement error at ADD_SUB_FLO.v(40): loop with non-constant loop condition must terminate within 250 iterations I searched and it seems that since Quartus can't be sure what will be the size of "ctrl_align" resultant it won't synthesize. Quartus site says I can edit the .qsf file, But I couldn't find in my file any set_global_assignment -name VERILOG_NON_CONSTANT_LOOP_LIMIT 300 Moreover, I'm somehow impressed that the book teach that step with a wrong code, not syntesizable, I also wish to actually fix the problem not to workaround, what can I do?
