10 years agoQuartus complaint: My LOOP is too big? But the code is from the book, what's wrong?
Hello friends. I'm trying to make addition and subtraction of floating point. My guide is a book "Computer Arithmetic and Verilog HDL Fundamentals" by Cavanagh. Inside the module he use a code for al...
10 years ago --- Quote Start --- Just because you can write HDL doesnt mean it makes sense in hardware. HDL is also meant to produce behavioral code to aid simulation that is not for use in a real design. --- Quote End --- I was under the conception that HDL is for designing chips or hardware itself, so what's the point to make a book with no synthesizable coding in HDL in the first instance. I can understand it for Test Benchs because they won't become a chip ever. Updating: If direct verilog isn't correct for doing this kind of operation, would it be a better way to design a kind of processor, with registers, stacks, simple add and subs? I know I could easily do this equation in Assembly.
