NYao's avatar
NYao
6 years ago
Quartus中的路径约束
我需要在Qartus 18.1中做3个信号的路径约束。将三个寄存器的输出连到3个相邻的管脚上,要求3个信号的延时相同,最好走的路径也相近,请问怎么约束?​
  • KhaiChein_Y_Intel's avatar
    KhaiChein_Y_Intel
    You may use the set_max_skew constraint to perform maximum allowable skew analysis between sets of registers or ports.
    If you want to set the maximum allowable delay, you may use set_max_delay to specifies a maximum delay exception for a given path.
    KhaiY
  • NYao's avatar
    NYao
    hi,
    除了约束skew,怎样固定布线路径?​
  • NYao's avatar
    NYao
    你好,
    我能够把我的输出寄存器给约束位置吗?​
  • NYao's avatar
    NYao
    使用什么语法约束?有没有例子?​
    KhaiChein_Y_Intel
    You can create the Logic Lock region using the GUI or qsf assignment.
    For example,
    1) use the assignment below to create a new placement region with bounding box
    coordinates X46 Y36 X65 Y49:
    set_instance_assignment -name PLACE_REGION "X46 Y36 X65 Y49" -to <node names>
    2) use the assignment below to create a routing region with bounding box coordinates X46 Y36 X65 Y49: set_instance_assignment -name ROUTE_REGION -to "X46 Y36 X65 Y49"
    Please note that all instances with a routing region assignment must have a respective placement region; the routing region must fully contain the placement region.
    KhaiY
