NYao
6 years agoQuartus中的路径约束
Hi, 我需要在Qartus 18.1中做3个信号的路径约束。将三个寄存器的输出连到3个相邻的管脚上,要求3个信号的延时相同,最好走的路径也相近,请问怎么约束?
KhaiChein_Y_Intel
6 years agoHi,
You can create the Logic Lock region using the GUI or qsf assignment.
For example,
1) use the assignment below to create a new placement region with bounding box
coordinates X46 Y36 X65 Y49:
set_instance_assignment -name PLACE_REGION "X46 Y36 X65 Y49" -to <node names>
2) use the assignment below to create a routing region with bounding box coordinates X46 Y36 X65 Y49: set_instance_assignment -name ROUTE_REGION -to "X46 Y36 X65 Y49"
Please note that all instances with a routing region assignment must have a respective placement region; the routing region must fully contain the placement region.
KhaiY
