NYao
6 years agoQuartus中的路径约束
Hi, 我需要在Qartus 18.1中做3个信号的路径约束。将三个寄存器的输出连到3个相邻的管脚上,要求3个信号的延时相同,最好走的路径也相近,请问怎么约束?
KhaiChein_Y_Intel
6 years agoHi,
You may use the set_max_skew constraint to perform maximum allowable skew analysis between sets of registers or ports.
If you want to set the maximum allowable delay, you may use set_max_delay to specifies a maximum delay exception for a given path.
KhaiY
