FabianL's avatar
FabianL
3 months ago
QSYS Subsystem Export Port order
I'm having a hierarchical QSYS System which uses other QSYS file as subsystem. My problem is, that I cannot find a way to reliable define the order of export Ports of the subsystem, i.e. the graphical order in which they appear in the instantiating top level.
The Thread is somehow related to this: Ordering of Ports for exported Qsys signal conduits | Altera Community, but the solution proposed there does not work.
System Information:
  • Quartus Pro 25.3
  • Device Arria 10
What I have done so far to try to customize the order of export Ports:
  1. Remove all the export ports, save the .qsys subsystem and re-export the port in the correct order, as proposed in the above mentioned thread
    • ==> no effect at all the export ports appeared in the top level in exact the same order as before
  2. Manually edit the XML file of the .qsys subsystem and rearrange the listed ports in the desired order.
  3. Remove the driving IP core for all export ports and readd the IP cores in the desired order of their export ports
    • ==> This actually had an effect, but this basically means rewriting the whole QSYS subsystem which is not an option.
After all of the above mentioned steps, I execute a "Refresh System and Reload all Components".
Am I missing something? What is the officially recommended way by Altera to define the order of export Ports of a QSYS Subsystem.
NOTE: This only corresponds to QSYS subsystem. It is not a problem with custom IP files based on any HDL
I'm thankful for any advice.
best regards
Fabian
  • FabianL's avatar
    FabianL
    So I assume there it is simply not intended to be possible by Altera, is that correct?
    • RichardT_altera's avatar
      RichardT_altera
      Sorry for the delay. I haven’t had any success finding a way to change the Qsys subsystem export port order.
      I will likely file an enhancement request with the engineering team.
      Richard Tan
      • FabianL's avatar
        FabianL
        Thanks for forwarding the request to the engineering team.
        best regards
        Fabian
  • FabianL's avatar
    FabianL
    No unfortunately both variants do not work:
    • Component Instantiation Tab is empty for .qsys submodules.
    • The Interface Requirements tab shows even a different Port order than what is in the XML .qsys file or to what is the order in the GUI in the top level.
  • sstrell's avatar
    sstrell
    I know this works for individual components, but try selecting the added subsystem and then go to the Component Instantiation tab.  Can you click and drag the interfaces on the Signals and Interfaces tab?
    If not there, try opening the subsystem .qsys and then looking at the Interface Requirements tab.  The left side of that tab shows the interfaces of the current system and I forget if you can drag and reorder them there.
  • FabianL's avatar
    FabianL
    The Interface looks like this currently:
    I expected the Ports to have the same order as in the .qsys XML file:
    <altera:altera_interface_boundary>
      <altera:interface_mapping altera:name="clk322m_in" altera:internal="clk322m_bridge.in_clk" altera:type="clock" altera:dir="end"></altera:interface_mapping>
      <altera:interface_mapping altera:name="clk_90m_in" altera:internal="clk_90m.in_clk" altera:type="clock" altera:dir="end"></altera:interface_mapping>
      <altera:interface_mapping altera:name="clk_pcie_in" altera:internal="clk_pcie.in_clk" altera:type="clock" altera:dir="end"></altera:interface_mapping>
      <altera:interface_mapping altera:name="reset" altera:internal="reset_bridge_0.in_reset" altera:type="reset" altera:dir="end"></altera:interface_mapping>
      <altera:interface_mapping altera:name="reset_pcie" altera:internal="reset_pcie.in_reset" altera:type="reset" altera:dir="end"></altera:interface_mapping>
      <altera:interface_mapping altera:name="mm_bridge_0_m0" altera:internal="mm_bridge_0.m0" altera:type="avalon" altera:dir="start"></altera:interface_mapping>
    </altera:altera_interface_boundary>
    As for the reason, why I would like to define the order or exported Ports:
    • If using multiple QSYS files in a hierarchy, it can get very confusing and difficult to read if the interface ports of submodules appear unordered.
    • Especially for submodules with different clock domains and/or multiple Avalon Ports it would be extremely beneficial from a documentation & readability point of view to be able to arrange the Ports in a meaningful way.
    In fact this has been possible in other versions of Quartus. I can definitely state, that it has worked flawless with Quartus 21.1 Standard.
    best regards
    Fabian
  • Could you share a screenshot showing your expected result and the actual result?
    Is there any specific IP in the subsystem for which you want to change the order of the exported ports?
    For better understanding, could you also explain why you would like to define the order of the exported ports in a Platform Designer subsystem?
    Richard Tan
  • FabianL's avatar
    FabianL
    Concerning 2. the modified section in the .qsys XML file is looking like this:
