FabianL
8 months agoQSYS Subsystem Export Port order
Hello, I'm having a hierarchical QSYS System which uses other QSYS file as subsystem. My problem is, that I cannot find a way to reliable define the order of export Ports of the subsystem, i.e. t...
RichardT_altera
8 months agoCould you share a screenshot showing your expected result and the actual result?
Is there any specific IP in the subsystem for which you want to change the order of the exported ports?
For better understanding, could you also explain why you would like to define the order of the exported ports in a Platform Designer subsystem?
Richard Tan
