PCIe hard IP BAR to On-chip memory addressing
using Cyclone IV hard ip and On-chip memory 32B mapped to 0x-0x1F
BAR0 mapped to 0xA1200000-0xA0001F
Reading BAR0 at offset 0 should have access first byte of On-chip memory? Reading 0xff instead of memory content.
May I know if you enable the PCIe BAR0? Have you try to performed SignalTap?
- JohnT_Altera
Could you share with me your Quartus design? How do you confirm that you are reading the correct addressing? Have you try to use SignalTap to tap the on chip memory IP interface?
- Markgel
Attached the design. Regarding the addressing - trying to read and write to BAR0, but can't catch any activity for On chip memory signals using the SignalTap.
- JohnT_Altera
From your design, I observed that you are not using the correct clock on the on chip memory. The clock should be from the PCIe Clock output so that the clock is sync between Bar 0 and On Chip Memory.
Please refer to https://fpgacloud.intel.com/devstore/platform/14.0.0/Standard/an-456-pci-express-high-performance-reference-design-for-cyclone-iv-gx-fpga/ for the design example.
- Markgel
tried to implement design suggested (attached), but still reading 0xFF from the BARs memory:
- JohnT_Altera
- Markgel
Hi
Yes, indeed was a problem that win driver blocked the BAR0. Thanks for support.
BR,
Mark.
- JohnT_Altera
May I know if the issue is resolved after you unblock the BAR0?
- Markgel
Yes, it does - can access to the BARs memory.
- JohnT_Altera
