Markgel
5 years agoPCIe hard IP BAR to On-chip memory addressing
using Cyclone IV hard ip and On-chip memory 32B mapped to 0x-0x1F
BAR0 mapped to 0xA1200000-0xA0001F
Reading BAR0 at offset 0 should have access first byte of On-chip memory? Reading 0xff instea...
- 5 years ago
May I know if you enable the PCIe BAR0? Have you try to performed SignalTap?
JohnT_Altera
5 years agoHi,
Could you share with me your Quartus design? How do you confirm that you are reading the correct addressing? Have you try to use SignalTap to tap the on chip memory IP interface?
- Markgel5 years ago
Attached the design. Regarding the addressing - trying to read and write to BAR0, but can't catch any activity for On chip memory signals using the SignalTap.
