Markgel
5 years agoPCIe hard IP BAR to On-chip memory addressing
using Cyclone IV hard ip and On-chip memory 32B mapped to 0x-0x1F
BAR0 mapped to 0xA1200000-0xA0001F
Reading BAR0 at offset 0 should have access first byte of On-chip memory? Reading 0xff instea...
- 5 years ago
May I know if you enable the PCIe BAR0? Have you try to performed SignalTap?
JohnT_Altera
5 years agoHi,
From your design, I observed that you are not using the correct clock on the on chip memory. The clock should be from the PCIe Clock output so that the clock is sync between Bar 0 and On Chip Memory.
Please refer to https://fpgacloud.intel.com/devstore/platform/14.0.0/Standard/an-456-pci-express-high-performance-reference-design-for-cyclone-iv-gx-fpga/ for the design example.
- Markgel5 years ago
tried to implement design suggested (attached), but still reading 0xFF from the BARs memory:
