Old Verilog Library not recognized by Compiler
I have an old Verilog design which I am trying to compile into a MAX10M08. My problem is that the synthesis analysis doesn't recognize either the libraries I have specified for the project or doesn't recognize the library parts. I have made sure that the paths are correct. The original design is for a 65C02 which was made into an ASIC 25 years ago but, it should still work. I have selected Verilog 1995 as the HDL input. Attached is a small part of one of the libraries. It shows the first three modules, aa21, aa22 and aa31. There are hundreds of other modules like this in the library but none are recognized. Should there be a header a the top of the file, in order for Quartus II to recognize it as a library file? I have worked on this for a while. The error message I get is like this for all the parts:
Error (12006): Node instance "NA21_U248" instantiates undefined entity "na21". Ensure that required library paths are specified correctly, define the specified entity, or change the instantiation. If this entity represents Intel FPGA or third-party IP, generate the synthesis files for the IP.
The one node line of code which generated the error is this:
na21 NA21_U248 (.Q(N285),.A(N138),.B(N260))
The two libraries in the project are identical except that one has lower case na21 modules and the other has upper case NA21 modules.
Can anyone help me with this?
Thank You.
- sstrell
Where are you putting the library file and how are you referencing the file? In Quartus, you need to point to where the file is located (if it's not in the project directory) from Tools -> Options -> IP Catalog Search Locations.
In the code for your design, you should also have `include to point to the file.
Have you tried these?
#iwork4intel
- SyafieqS
Im not sure what version and type of Quartus you use, but as I know the support features for language type is varies for different language and also limited for each Quartus and this issue could be one of the reason the Verilog library is not recognized. Can refer to link below for comparison support features Quartus
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/po/ss-quartus-comparison.pdf
- MZorr1
Thank You for the response. I am using the Quartus Prime Lite Edition (Free). In checking the comparison chart between editions, it does says it supports Verilog design entry. Seems that it should work but, I don't really know if the library sample I provided in my post, has the correct module syntax/structure, to be recognized as a valid library.
- SyafieqS
Yes it could be due to your addressing path maybe you can double check it.
- MZorr1
Thank You for the responses. I do have the two libraries I need to use, in the project directory and also specified in the project libraries and in the IP library selections. The paths are correct.
I don't have them in the "Include" statement at the top of the code for the design. Could you give me an example for the Include statement in the code? The two library names are "ASICUC.LIB" and "ASICLC.LIB".
I appreciate your response.
This is how the top of the project looks like:
`timescale 1ns/10ps
module TOPLEVEL (ADCZ,CMPZ,ICKPC,ICKSR0,ICKSR1,ICKSR6,ICKSR7,ICLKSTP,ICLRMH,
ICNAU0,ICNAU1,ICNAU2,ICNAU3,ICNAU4,IDEN,IFETCH,INCEN,IRDACDO,
IRDMDDO,IRDMHDO,IRDMLAL,IRDMLDO,IRDPCAL,IRDPHDO,IRDPLDO,IRDPSDO,
