MZorr1
6 years agoOld Verilog Library not recognized by Compiler
I have an old Verilog design which I am trying to compile into a MAX10M08. My problem is that the synthesis analysis doesn't recognize either the libraries I have specified for the project or doesn't...
sstrell
6 years agoWhere are you putting the library file and how are you referencing the file? In Quartus, you need to point to where the file is located (if it's not in the project directory) from Tools -> Options -> IP Catalog Search Locations.
In the code for your design, you should also have `include to point to the file.
Have you tried these?
#iwork4intel
