10 years agoNeed advice about coding style
Hello I'm Alex and I am novice for VHDL coding. if my english awful pls forgive me.
I trying to understand VHDL PROCESS statement. I try with 1bit full adder with carry save function in Quartus2 v15. I write down code:LIBRARY IEEE;
USE IEEE.std_logic_1164.ALL;
-- truth-table of full-adder
-- with three inputs: ci{carry_in}, a{first in} and b{second in}
-- and two ouputs: s{sum} and co{carry_out}
-- ci a b | s co
-- 0 0 0 | 0 0
-- 0 0 1 | 1 0
-- 0 1 0 | 1 0
-- 0 1 1 | 0 1
-- 1 0 0 | 1 0
-- 1 0 1 | 0 1
-- 1 1 0 | 0 1
-- 1 1 1 | 1 1
ENTITY full_add_1bit IS
PORT (
ci : IN STD_LOGIC;
a : IN STD_LOGIC;
b : IN STD_LOGIC;
s : OUT STD_LOGIC;
co : OUT STD_LOGIC
END full_add_1bit;
ARCHITECTURE b OF full_add_1bit IS
BEGIN
p0 : PROCESS(ci, a, b)
VARIABLE
aab,
aob,
axb,
sxc : STD_LOGIC;
BEGIN
aab := a AND b;
axb := a XOR b;
sxc := axb XOR ci;
s <= sxc;
IF ci = '0' THEN
co <= aab;
ELSIF ci = '1' THEN
aob := axb XOR aab; -- the same as (a OR b)
co <= aob;
END IF;
END PROCESS p0;
END b; but during compilation i recieves message --- Quote Start --- Warning (10631): VHDL Process Statement warning at full_add_1bit.vhd(30): inferring latch(es) for signal or variable "co", which holds its previous value in one or more paths through the process --- Quote End --- I follow the simple logic - let's compute new values then do all signal assignments and the question is question1 : does pressure on variables so need?! I rewrite architecture to new one, let's compiler do all work: ARCHITECTURE b1 OF full_add_1bit IS
BEGIN
VARIABLE
result_i : INTEGER;
VARIABLE
result_v : STD_LOGIC_VECTOR (0 TO 1);
BEGIN
result_i := CONV_INTEGER(a)+CONV_INTEGER(b)+CONV_INTEGER(ci);
result_v := CONV_STD_LOGIC_VECTOR (result_i, 2);
co <= result_v(0);
s <= result_v(1);
END PROCESS p0;
END b1; Finally i make schematic for this with 2mux1 blocks as for fun... in the attachments. never use schematic for establishing any equation - you waste your time. But result is the same with that scheme. question 2: how to find the way to good coding style?
