11 years agoNeed advice about coding style
Hello I'm Alex and I am novice for VHDL coding. if my english awful pls forgive me. I trying to understand VHDL PROCESS statement. I try with 1bit full adder with carry save function in Quartus2 v...
11 years agoLet's go further.
I see that built-in function has pipelining, I want to use it in my code, Im' confused a little bit. Any idea are welcome. I wrote comments, is it good style for VHDL comments? What should be commented? The comments should be present in code for person who will be read it. I remove initial values. I believe it is useful in simulation only, correct me if it is falsehood.LIBRARY IEEE;
USE IEEE.std_logic_1164.ALL;
USE IEEE.numeric_std.ALL;
-- addition of two operands with carry-save
ENTITY full_adder_Nbit IS
GENERIC (
N : POSITIVE := 4 -- default operands size
PORT (
clk : IN STD_LOGIC; -- clock signal
ci : IN STD_LOGIC; -- carry-in
a : IN UNSIGNED (N-1 DOWNTO 0); -- augend
b : IN UNSIGNED (N-1 DOWNTO 0); -- addend
s : OUT UNSIGNED (N-1 DOWNTO 0); -- sum
co : OUT STD_LOGIC -- carry-out
END full_adder_Nbit;
ARCHITECTURE b OF full_adder_Nbit IS
SIGNAL
out_s : UNSIGNED (N-1 DOWNTO 0); -- new value for sum
SIGNAL
out_co : STD_LOGIC; -- new value for carry-out
BEGIN
-- provide outputs with recently calculated values (from p1)
p0 : PROCESS (clk)
BEGIN
IF rising_edge(clk) THEN
co <= out_co;
s <= out_s;
END IF;
END PROCESS p0;
-- calculate new values that will be outputed (for p0)
p1 : PROCESS (ci, a, b)
VARIABLE
result_v : UNSIGNED (N DOWNTO 0); -- intermediate result
BEGIN
result_v := ('0' & a) + ('0' & b) + ('0' & ci);
out_co <= result_v(N);
out_s <= result_v(N-1 DOWNTO 0);
END PROCESS p1;
END b;
