11 years agoNeed advice about coding style
Hello I'm Alex and I am novice for VHDL coding. if my english awful pls forgive me. I trying to understand VHDL PROCESS statement. I try with 1bit full adder with carry save function in Quartus2 v...
11 years agoOk. I conclude - just describe your intetion as algorithm then compiler will decide about implemantion. By the way, looking at code for full_adder_nbit is there upper limit for N when the logic sysnthesis with plus operator will be worst than using build-in PARALLEL_ADD structure , the last i found in IP-catalog. It is also about coding style - using built-in functions and blocks rather than reinventing one's own.
