11 years agoNeed advice about coding style
Hello I'm Alex and I am novice for VHDL coding. if my english awful pls forgive me. I trying to understand VHDL PROCESS statement. I try with 1bit full adder with carry save function in Quartus2 v...
11 years agoIt seems that rising_edge evaluated at compile time in function.
so i chage to procedure procedure regCreate(
signal clk : IN std_logic; aclr : IN std_logic;
data : IN unsigned; signal reg: OUT unsigned) is
begin
if aclr = '1' then
reg <= to_unsigned(0, data'length);
elsif rising_edge(clk) then
reg <= data;
end if;
end regCreate;
signal clk : IN std_logic; aclr, ce : IN std_logic;
begin
if aclr = '1' then
if ce = '1' then
reg <= data;
end if;
end if;
end regCreate; It works. test code library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.numeric_std.all;
use work.utility_pkg.all;
entity PulseGenerator is
generic(
REG_WIDTH : natural := 4
port(
reset
clk,
wrn,
wrk,
start : IN std_logic;
data : IN unsigned(REG_WIDTH-1 downto 0);
z : OUT std_logic
end PulseGenerator;
architecture rtl1 of PulseGenerator is
signal reg_N, reg_K : unsigned(data'range);
begin
regCreate(wrn, reset, data, reg_N);
regCreate(clk, reset, wrk, data, reg_K);
z <= isRegZero(reg_N) and isRegZero(reg_K);
end rtl1;
