--- Quote Start --- Looks like its internal to the adder and multipler, nothing you can do about it. You can turn off these warnings in modelsim by going to Simulate -> Runtime Options -> tick "Ignore warnings from numeric_std and synopsys packages" --- Quote End --- Thank you very much. Your knowledge are very good. - Altera_Forum
I implement the continuous transfer function of the second order low pass filter by VHDL. I don't know why my result are very strange. And I saw a lot of warning when I compile it. Do this wanning affect to my result?
This is warning: --- Quote Start --- Warning (14130): Reduced register "Yn[0]~reg0" with stuck data_in port to stuck value GND Warning (14130): Reduced register "Yn[1]~reg0" with stuck data_in port to stuck value GND Warning (14130): Reduced register "Y1[0]" with stuck data_in port to stuck value GND Warning (14130): Reduced register "Y1[1]" with stuck data_in port to stuck value GND Warning (14130): Reduced register "Y2[0]" with stuck data_in port to stuck value GND Warning (14130): Reduced register "Y2[1]" with stuck data_in port to stuck value GND Warning (14130): Reduced register "Y3[0]" with stuck data_in port to stuck value GND Warning (14130): Reduced register "Y3[1]" with stuck data_in port to stuck value GND Warning (14130): Reduced register "Y4[0]" with stuck data_in port to stuck value GND Warning (14130): Reduced register "Y4[1]" with stuck data_in port to stuck value GND Warning: Output pins are stuck at VCC or GND Warning (13410): Pin "Yn[0]" stuck at GND Warning (13410): Pin "Yn[1]" stuck at GND Warning: The high junction temperature operating condition is not set. Assuming a default value of '85'. Warning: The low junction temperature operating condition is not set. Assuming a default value of '0'. Warning: Found 16 output pins without output pin load capacitance assignment Info: Pin "Yn[0]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis Info: Pin "Yn[1]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis Info: Pin "Yn[2]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis Info: Pin "Yn[3]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis Info: Pin "Yn[4]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis Info: Pin "Yn[5]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis Info: Pin "Yn[6]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis Info: Pin "Yn[7]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis Info: Pin "Yn[8]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis Info: Pin "Yn[9]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis Info: Pin "Yn[10]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis Info: Pin "Yn[11]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis Info: Pin "Yn[12]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis Info: Pin "Yn[13]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis Info: Pin "Yn[14]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis Info: Pin "Yn[15]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis Warning: Following 2 pins have nothing, GND, or VCC driving datain port -- changes to this connectivity may change fitting results Info: Pin Yn[0] has GND driving its datain port Info: Pin Yn[1] has GND driving its datain port Warning: The Reserve All Unused Pins setting has not been specified, and will default to 'As output driving ground'. Warning: Found pins functioning as undefined clocks and/or memory enables Info: Assuming node "CLK" is an undefined clock Info: Assuming node "CLK_40n" is an undefined clock --- Quote End --- How to reject this wanning? And this is my code:LIBRARY IEEE; USE IEEE.std_logic_1164.all; USE IEEE.std_logic_arith.all; USE IEEE.std_logic_signed.all; LIBRARY lpm; USE lpm.LPM_COMPONENTS.ALL; ENTITY STEP IS port(CLK, CLK_40n :IN STD_LOGIC:='0'; X0 :IN STD_LOGIC_VECTOR(15 downto 0):=(OTHERS =>'0'); Yn :BUFFER STD_LOGIC_VECTOR(15 downto 0):=(OTHERS =>'0')); END STEP; ARCHITECTURE STEP_arch OF STEP IS SIGNAL A0,A1,A2,A3,A4 :STD_LOGIC_VECTOR(15 downto 0):=(OTHERS =>'0'); SIGNAL B1,B2,B3,B4 :STD_LOGIC_VECTOR(15 downto 0):=(OTHERS =>'0'); SIGNAL Y4,Y3,Y2,Y1 :STD_LOGIC_VECTOR(15 downto 0):=(OTHERS =>'0'); SIGNAL X1,X2,X3,X4 :STD_LOGIC_VECTOR(15 downto 0):=(OTHERS =>'0'); SIGNAL mula,mulb :STD_LOGIC_VECTOR(15 downto 0):=(OTHERS =>'0'); SIGNAL mulr :STD_LOGIC_VECTOR(31 downto 0):=(OTHERS =>'0'); SIGNAL adda,addb,addr :STD_LOGIC_VECTOR(15 downto 0):=(OTHERS =>'0'); SIGNAL CNT :STD_LOGIC_VECTOR(4 downto 0):=(OTHERS =>'0'); BEGIN mull: lpm_mult generic map(LPM_WIDTHA=>16,LPM_WIDTHB=>16,LPM_WIDTHS=>16,LPM_WIDTHP=>32, LPM_REPRESENTATION=>"SIGNED",LPM_PIPELINE=>1) port map(dataa=> mula,datab=> mulb,clock=> clk,result=> mulr); adder1: lpm_add_sub generic map(lpm_width=>16,LPM_REPRESENTATION=>"SIGNED",lpm_pipeline=>1) port map(dataa=>adda,datab=>addb,clock=> clk,result=>addr); --Q15 A0 <= "0000000000000011";--3 A1 <= "0000000000001011";--11 A2 <= "0000000000010001";--17 A3 <= "0000000000001011";--11 A4 <= "0000000000000011";--3 B1 <= "0101110100111111";--23871 B2 <= "1001101000010100";--- -26092 B3 <= "0011000101011101";---12637 B4 <= "1111011011111100";--- -2308 GEN:block BEGIN PROCESS(CLK_40n) BEGIN IF CLK_40n'EVENT and CLK_40n='1' THEN CNT <=CNT+1; IF CNT="00000" THEN mula <= A0; mulb <= X0; ELSIF CNT="00001" THEN adda <= mulr(30 downto 15); mula <= A1; mulb <= X1; ELSIF CNT="00010" THEN addb <= mulr(30 downto 15); mula <= A2; mulb <= X2; ELSIF CNT="00011" THEN adda <= addr; addb <= mulr(30 downto 15); mula <= A3; mulb <= X3; ELSIF CNT="00100" THEN adda <= addr; addb <= mulr(30 downto 15); mula <= A4; mulb <= X4; ELSIF CNT="00101" THEN adda <= addr; addb <= mulr(30 downto 15); mula <= B1; mulb <= Y1; ELSIF CNT="00110" THEN adda <= addr; addb <= mulr(30 downto 15); mula <= B2; mulb <= Y2; ELSIF CNT="00111" THEN adda <= addr; addb <= mulr(30 downto 15); mula <= B3; mulb <= Y3; ELSIF CNT="01000" THEN adda <= addr; addb <= mulr(30 downto 15); mula <= B4; mulb <= Y4; ELSIF CNT="01001" THEN adda <= addr; addb <= mulr(30 downto 15); ELSIF CNT="01010" THEN Yn <= (addr(15) & addr(12 downto 0) & "00"); ELSIF CNT="01011" THEN Y1 <= Yn; Y2 <= Y1; Y3 <= Y2; Y4 <= Y3; X4 <= X3; X3 <= X2; X2 <= X1; X1 <= X0; CNT <= "00000"; END IF; END IF; END PROCESS; END BLOCK GEN; END STEP_arch; - Altera_Forum
Looks like you're clipping the values somewhere, and or slicing the wrong bits when taking the output from multipliers.
You'll have to take a look in your VHDL to try and find it. - Altera_Forum
--- Quote Start --- Looks like you're clipping the values somewhere, and or slicing the wrong bits when taking the output from multipliers. You'll have to take a look in your VHDL to try and find it. --- Quote End --- Thank Tricky I had already change my code. For example mulr(30 downto 15); mulr(15 downto 0); ... But it still have the same wanning. I don't know why. I had already attached my difference equation after Q15 format in this message. Could you check it for me? - Altera_Forum
Some warnings are related to code not shown in your post. Y1, Y2 are inputs in the shown code, not registers.
Some warnings are directly brought up by your code, you should be able to see the cause when looking sharp.
Not surprizing considering the assignmentWarning (13410): Pin "Yn" stuck at GND Warning (13410): Pin "Yn" stuck at GND
Because the post is only showing part of the filter code, I can't determine if it's operating according to your intentions now. You also didn't report the results for the final version. The warnings can be considered "normal operation" so far. As a general remark, I guess that the filter will be affected by arithmetic overflows with respective input data. Or did you downscale the coefficients to prevent it for all possible input values? But then, you would loose a lot of available dynamic. I also doubt, that you'll save much resources by time-multiplexing an adder and a multiplier compared to a full pipelined design using multiple adders and multipliers.Yn <= (addr(15) & addr(12 downto 0) & "00"); - Altera_Forum
--- Quote Start --- Some warnings are related to code not shown in your post. Y1, Y2 are inputs in the shown code, not registers. Some warnings are directly brought up by your code, you should be able to see the cause when looking sharp.
Because the post is only showing part of the filter code, I can't determine if it's operating according to your intentions now. You also didn't report the results for the final version. The warnings can be considered "normal operation" so far. As a general remark, I guess that the filter will be affected by arithmetic overflows with respective input data. Or did you downscale the coefficients to prevent it for all possible input values? But then, you would loose a lot of available dynamic. I also doubt, that you'll save much resources by time-multiplexing an adder and a multiplier compared to a full pipelined design using multiple adders and multipliers. --- Quote End --- Thank you very much for your support. May be I must spent more time for this. Up to now, I still don't understand this missing. And I still can not repair it. Thank againYn <= (addr(15) & addr(12 downto 0) & "00"); - Altera_Forum
When i make a *.mif file and i see the warning of quartus
--- Quote Start --- Warning: Assertion warning: altrom does not support Cyclone II device family -- attempting best-case memory conversions, but power-up states will be different for Cyclone II devices Warning: Converted TRI buffer or tri-state bus to logic, or removed OPNDRN Warning: Converting TRI node "lpm_rom:u1|otri[7]" that feeds logic to a wire Warning: Converting TRI node "lpm_rom:u1|otri[6]" that feeds logic to a wire Warning: Converting TRI node "lpm_rom:u1|otri[5]" that feeds logic to a wire Warning: Converting TRI node "lpm_rom:u1|otri[4]" that feeds logic to a wire Warning: Converting TRI node "lpm_rom:u1|otri[3]" that feeds logic to a wire Warning: Converting TRI node "lpm_rom:u1|otri[2]" that feeds logic to a wire Warning: Converting TRI node "lpm_rom:u1|otri[1]" that feeds logic to a wire Warning: Converting TRI node "lpm_rom:u1|otri[0]" that feeds logic to a wire --- Quote End --- What is the altrom? And how to correct this warning? Thanks - Altera_Forum
This is my code:
--- Quote Start --- LIBRARY IEEE; USE IEEE.std_logic_1164.all; LIBRARY lpm; USE lpm.LPM_COMPONENTS.ALL; USE IEEE.std_logic_arith.all; USE IEEE.std_logic_signed.all; ENTITY Ram_Rom IS PORT(clk: in std_logic; inaddress : in std_logic_vector(7 downto 0); data : out std_logic_vector(7 downto 0)); end Ram_Rom; ARCHITECTURE new_array_arch OF Ram_Rom IS signal data1 : STD_LOGIC_vector(7 downto 0); begin u1: lpm_rom GENERIC MAP(lpm_width=> 8, lpm_widthad=> 8, lpm_file=> "array.mif", lpm_address_control=> "registered", lpm_outdata=> "unregistered") PORT MAP(ADDRESS => inaddress, inclock=> clk, q => data1); Process(clk) begin if clk'event and clk='1' then data <= data1; end if; end process; end new_array_arch; --- Quote End --- When I compile it by Quartus. I saw no logic gate. But when I simulate it in waveforms it still right. Can you explain this for me? Thanks
