15 years agoWhen i make a *.mif file and i see the warning of quartus
--- Quote Start --- Warning: Assertion warning: altrom does not support Cyclone II device family -- attempting best-case memory conversions, but power-up states will be different for Cyclone II devices Warning: Converted TRI buffer or tri-state bus to logic, or removed OPNDRN Warning: Converting TRI node "lpm_rom:u1|otri[7]" that feeds logic to a wire Warning: Converting TRI node "lpm_rom:u1|otri[6]" that feeds logic to a wire Warning: Converting TRI node "lpm_rom:u1|otri[5]" that feeds logic to a wire Warning: Converting TRI node "lpm_rom:u1|otri[4]" that feeds logic to a wire Warning: Converting TRI node "lpm_rom:u1|otri[3]" that feeds logic to a wire Warning: Converting TRI node "lpm_rom:u1|otri[2]" that feeds logic to a wire Warning: Converting TRI node "lpm_rom:u1|otri[1]" that feeds logic to a wire Warning: Converting TRI node "lpm_rom:u1|otri[0]" that feeds logic to a wire --- Quote End --- What is the altrom? And how to correct this warning? Thanks
