17 years ago
It adds 3 and subtracts 1 instead of adding just 1
Hi!
I'm pretty new with vhdl and Quartus II and maybe this question is too obvious, but I spent three days on it and I cannot understand yet why is not working... I made a silly program, just adding one to a number, and just send one bit to the output. I tried to simulate it. There are no errors on Analysis & Synthesis, and no errors on EDA Netlist Writer. But the simulation is wrong (I don't obtain what I should)
1. I make a reset and "nombre" should be "0101010101", instead it is "0000000".
2. It should add 1 to this variable at each rising edge clock. Instead sometimes it adds 3 and then subtracts 1.
I cannot understand what's happening. I know it should be a really silly mistake from me, because this program is too simple, but I cannot find it. Moreover I've done a more complicated program and I had no problems. Can anybody help me, please?
Hier there is the code:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
library altera;
use altera.altera_primitives_components.all;
entity prova1 is
port
-- Input ports
clk : in std_logic;
reset : in std_logic;
-- Output ports
sortida : out std_logic
end prova1;
-- Library Clause(s) (optional)
-- Use Clause(s) (optional)
architecture arch_prova1 of prova1 is
signal nombre : std_logic_vector(9 downto 0):="0101010101";
begin
pr1: process(clk,reset,nombre)
begin
if reset='1' then
nombre<="0101010101";
else
if(rising_edge(clk)) then
nombre<=nombre+1;
else
nombre<=nombre;
end if;
end if;
end process pr1;
-- Add the library and use clauses before the design unit declaration
ff_sortida : DFF
port map (
d => nombre(4),
clk => clk,
clrn => not(reset),
prn => '1',
q => sortida
end arch_prova1;
