17 years agoNo problem (click on my reputation if you think my help is good),
for your problem now it seems that it's a timing problem. You can check it on the report after your compilation ended (see under the compilation report the timing section). If you've timing problem they could depend from a lot of thing: is your clock coming from a pin? Have you given the assignement to it in order to tell the compiler that it's a clock and that its period is 20ns? This will really help quartus and drive its compilation.
