17 years agoHi,
In your process, just typeprocess(reset,clk) : your process must be synchronous and then no other signal in sensibility list of process. if you type "process(reset,clk,nombre)" the process will be activated on any changes of nombre. you may use variable in this process. Because "nombre<=nombre+1;" is not obvious. and then typenombre <= var +1 ;. Sorry for my english, I'm french.
