How to properly constrain generated clock and synchronizer?
Hello!
In my Verilog design I have a 25Mhz board clock from which I derive a 100Mhz clock. Coming from an external Pin I have an asynchronous 4.77 Mhz clock which should drive the logic and be synchronized before (using the main clock):
always @(posedge clk_100Mhz_i)
begin
// Synchronizer chain... hopefully
clk4_del0 <= clk4_77_i; // SysClk from ext pin
clk4_del1 <= clk4_del0;
clk4_del2 <= clk4_del1;
end
// Used to clock internal regs
assign clock_4_77Mhz = clk4_del2;
// Sample
always @(posedge clock_4_77Mhz)
begin
timerIdx <= timerIdx +1;
endUnfortunately I get the following warning:
Warning (332060): Node: X8255_top:x8255|clk4_del2 was determined to be a clock but was found without an associated clock assignment....
I also get a warning about an unconstrained clock. I tried to use what the Timing Analyzer suggested and added the fourth line to my .SDC:
# Constrain clock port clk_25MHz_i
create_clock -period "25.0 MHz" -name clk_25MHz [get_ports clk_25MHz_i]
create_clock -period "4.77 MHz" -name clk_4_77MHz [get_ports clk_4_77_i]
create_clock -name {X8255_top:x8255|clk4_del2} -period 210without success.
What am I doing wrong?
- sstrell
With a PLL, that simplifies your .sdc. It should look like this with the info you've now provided:
create_clock -period 40 [get_ports clk_25MHz_i] -name clk_25MHz
derive_pll_clocks
derive_clock_uncertainty
create_generated_clock -source <output clock pin of PLL> -name clk_4_77MHz -divide_by 21 <output pin of clk4_del2 register>
set_false_path -from [get_clocks clk_25MHz] -to [get_clocks clk_4_77MHz ]
derive_pll_clocks has to come before any constraint that uses the clock from the PLL, so your order is wrong. For "output clock pin of PLL" and "output pin of clk4_del2 register", you'll need to use the Name Finder to find the actual names of the pins, accessible from the create_generated_clock dialog box in the Quartus Text Editor. "X8255_top/clk_100MHz" is not correct because that's what you have in your HDL code, which is not the same as the timing netlist used by the timing analyzer.
- sstrell
Assuming clock_4_77Mhz is a clock that is driving other logic in your design not shown in this code, it would need to be constrained as a generated clock, not a base clock, since it originates inside the device. There should also be a generated clock constraint for clk_100MHz_i since you say it is generated based on clk_25MHz_i. clk_4_77_i is technically not considered a clock by the timing analyzer since it goes into a data input of a register, not a clock pin, but clock_4_77Mhz is a clock. I highly recommend using a PLL to simplify all this.
So here's my best guess (without seeing your whole design) as to what your .sdc should look something like:
# use derive_pll_clocks if you're using a PLL (which I'd recommend because it simplifies all of this) or:
create_generated_clock -source [get_ports clk_25MHz_i] -multiply_by 4 <input clock pin of clk4_del0 register> -name clk_100MHz_i
create_generated_clock -source <input clock pin of clk4_del2 register> -name clk_4_77MHz -divide_by 21 <output pin of clk4_del2 register>
- fhw72
At first I'd like to thank you for taking your time. 🙂
Unfortunately I was not able to translate your recommandation into a working .SDC.
The 100Mhz clock in my design is created by a PLL instantiated in the top level module "X8255_top" (Name: clk_100Mhz, Output of the PLL: c0):
// // Instantiate clock generator/PLL // wire clk_100MHz; wire pll_locked; X8255_clkgen pll( .inclk0(clk_25MHz_i), .c0(clk_100MHz), .locked(pll_locked) );This is the .SDC I created:
(Please mind that the clk25/clk100 are asynchronous to the 4.77MHz clock; I added line 11 therefore)
# Constrain clock port clk_25MHz_i create_clock -period "25.0 MHz" -name clk_25MHz [get_ports clk_25MHz_i] create_generated_clock -source [get_pins X8255_top/clk_100MHz] -name clk_4_77MHz -divide_by 21 [get_pins clk4_del2] # Automatically apply a generate clock on the output of phase-locked loops (PLLs) # This command can be safely left in the SDC even if no PLLs exist in the design derive_pll_clocks derive_clock_uncertainty # Clocks are unrelated / asynchronous set_false_path -from [get_clocks clk_25MHz] -to [get_clocks clk_4_77MHz ]Unfortunately I now get these warnings (shortened to make more readable):
Warning (332174): Ignored filter at X8255_top.sdc(3): X8255_top/clk_100MHz could not be matched with a pin
Warning (332174): Ignored filter at X8255_top.sdc(3): clk4_del2 could not be matched with a pin
Warning (332049): Ignored create_generated_clock at X8255_top.sdc(3): Argument -source is an empty collection
Warning (332174): Ignored filter at X8255_top.sdc(11): clk_4_77MHz could not be matched with a clock
Warning (332049): Ignored set_false_path at X8255_top.sdc(11): Argument <to> is an empty collection
Info (332050): set_false_path -from [get_clocks clk_25MHz] -to [get_clocks clk_4_77MHz]
Info (13166): Register X8255_top:x825..... is being clocked by X8255_top:x8255|clk4_del2
- JonWay_altera
There is a kdb on the warning:
I would agree that a PLL would simplify the sdc.
- fhw72
@sstrell:
Many thanks! Your explanation and the provided lines helped to solve the problem
and finally *understand* it!
- fhw72
@sstrell:
I'm now trying to constrain the inputs and outputs of my design and appended these lines:
# Constrain the input I/O path
set_input_delay -clock clk_1MHz -max 5 [all_inputs]
set_input_delay -clock clk_1MHz -min 0 [all_inputs]
# Constrain the output I/O path
set_output_delay -clock clk_1MHz -max 5 [all_outputs]
set_output_delay -clock clk_1MHz -min -1 [all_outputs]
5ns is the delay for the level shifters used on the in- and outputs of the design.
However I always get a setup violation?
Do you have an idea what I'm doing wrong?
PS: What should I do with 'altera_reserved_tck' which appears in my ReporT?
- sstrell
First of all, you need to define two virtual clocks, clock constraints for the clocks that drive the "upstream" and "downstream" devices. These constraints will have no target:
create_clock -period <period> -name <custom name for virtual clock> [-waveform <rise fall>]
Your set_input[output]_delay constraints need to reference the virtual clocks. (What is clk_1MHz?)
Next, the value you use for these constraints is calculated based on the max and min external delays to and from the FPGA for inputs and outputs, respectively.
There's a lot to this, so I'd recommend reviewing this online training for details:
https://www.intel.com/content/www/us/en/programmable/support/training/course/odsw1118.html
- fhw72
Ups... I mixed up the SDC from another similar project; it should have been:
clk_4_77MHz (instead of clk_1Mhz)
What do you mean by Up- and downstream devices?
What frequency do I have to use for the virtual clocks and why two virtual clocks?
I will dig through the tutorials asap... but right now I'm stuck. :-(
Maybe you also have a pointer to a good example too?
