fhw72
7 years agoHow to properly constrain generated clock and synchronizer?
Hello! In my Verilog design I have a 25Mhz board clock from which I derive a 100Mhz clock. Coming from an external Pin I have an asynchronous 4.77 Mhz clock which should drive the logic and be synch...
fhw72
7 years agoUps... I mixed up the SDC from another similar project; it should have been:
clk_4_77MHz (instead of clk_1Mhz)
What do you mean by Up- and downstream devices?
What frequency do I have to use for the virtual clocks and why two virtual clocks?
I will dig through the tutorials asap... but right now I'm stuck. :-(
Maybe you also have a pointer to a good example too?
