fhw72
7 years agoHow to properly constrain generated clock and synchronizer?
Hello! In my Verilog design I have a 25Mhz board clock from which I derive a 100Mhz clock. Coming from an external Pin I have an asynchronous 4.77 Mhz clock which should drive the logic and be synch...
sstrell
7 years agoFirst of all, you need to define two virtual clocks, clock constraints for the clocks that drive the "upstream" and "downstream" devices. These constraints will have no target:
create_clock -period <period> -name <custom name for virtual clock> [-waveform <rise fall>]
Your set_input[output]_delay constraints need to reference the virtual clocks. (What is clk_1MHz?)
Next, the value you use for these constraints is calculated based on the max and min external delays to and from the FPGA for inputs and outputs, respectively.
There's a lot to this, so I'd recommend reviewing this online training for details:
https://www.intel.com/content/www/us/en/programmable/support/training/course/odsw1118.html
