That variance seems a little large, but is probably correct. My rule of thumb is that the slow corner is always twice the fast corner.
What device and version of Quartus? (Old versions, and I'm talking years ago, weren't as good meeting timing constraints like this). Do you have the Optimize Multi-Corner option checked? I would try that first, as it would explain why it can't meet the fast corner.
Note that your constraints are pretty difficult. You have a 0ns hold relationship, with a -11ns min delay externally. That means the FPGA needs to get its data out in greater than 11ns at the Fast Corner. So if it were at something like 15ns, then doubling that for the slow corner would be 30ns. But you have a 40ns setup relationship and 11ns of that are chewed up externally, so the FPGA has 29ns to work with, i.e. the 30ns output delay would fail.
In general, if you need a long output delay, the quick trick is to drive it out on the falling edge. That adds a half-cycle delay that is PVT invariant, i.e. it's fixed. This should buy you a lot. A plug here, but you might want to look at the I/O section of the first chapter Getting Started in the TimeQuest guide I put on the alterawiki. Might help.
