It probably wouldn't work with 2x difference. You're asking for the output delay to be greater than 12ns and less than 25ns. Technically it's possibly, but that's really, really difficult to dial into. Phase-shifts or clocking on the falling edge tend to be much better ways to solve something like this.
(I'm guessing you're in the slowest speed device. That makes the spread a lot larger, as you basically get everything out of the fab. If the fab starts producing faster parts, it can still be marked as the slowest, which is another reason the spread is so large. A faster speed grade will reduce this variance, but I think there are probably other ways around this.)
