High-speed transmission interface at around 3 meters for FPGA to FPGA communication
I’m looking for a high-speed transmission interface at around 3 meters for FPGA to FPGA communication.
My development environment:
- MAX10 10m08sae144c8g
- Quartus Prime Lite 23.1.1
Currently, I am considering options like LVDS and dividing the task into two parts:
- Writing the transmission interface myself
- Using the IP Catalog
Considering that I am new to the Intel FPGA development environment and not very familiar with Quartus Prime and the IP Catalog, I decided to first try writing the transmission interface myself. Here is my design:
LVDS Transmitter:
- Input: Enable
- Output: lvds_clk & lvds_data
LVDS Receiver:
- Input: lvds_clk & lvds_data
- Output: 12-pin IO
I have completed writing my transmission interface and confirmed the transmission signal using an oscilloscope and logic analyzer.
I am transmitting a fixed 12-bit data, but the receiving interface is still unable to correctly receive the data according to the transmitted signal.
(Using LVTTL to test the transmission and reception logic for now, not using the LVDS interface.)
This is my transmission signal:
My Verilog receiver module:
Receive data on the rising edge of lvds_clk.
(gpio_1、gpio_2 are just for my observation purposes)
module lvds_receiver (
input wire clk,
input wire reset,
input wire lvds_clk,
input wire lvds_data,
output reg [11:0] data_out,
output reg gpio_1,
output reg gpio_2
reg [3:0] loop = 0;
reg [11:0] data_reg = 0;
always @(posedge lvds_clk or negedge reset) begin
if(!reset) begin
data_reg <= 12'h0;
loop <= 4'd0;
gpio_1 <= 1'b0;
gpio_2 <= 1'b0;
end
else begin
if(loop == 4'd11) begin
data_out <= {data_reg[10:0], lvds_data};
loop <= 4'd0;
gpio_1 <= ~gpio_1;
end
else begin
data_reg <= {data_reg[10:0], lvds_data};
loop <= loop + 1'b1;
gpio_2 <= ~gpio_2;
end
end
end
endmoduleMy ModelSIM simulations:
Transmit 0xABD (101010111101) and output to 12 pins in parallel after receiving.
FPGA self-transmission and self-reception simulations (FPGA to FPGA) of the transmission waveform :
But the actual results are different from the simulated ones.
My question:
1. I can’t figure out why the actual results and the simulation don’t match. I need help. Is there something I might have overlooked?
2. Regarding the use of the IP Catalog, I am still researching how to use the Soft LVDS IP. I haven’t found a detailed procedure for using this IP yet.
3. What interfaces can be considered for FPGA transmission over a distance of 3 meters?
- FvM
Your receiver is missing a frame synchronization mechanism.- Scarlet
Indeed, I have found that there is no frame synchronization.
My initial judgment is that during FPGA power-up, it has led to a misjudgment of the rising edge of the LVDS clock.
I would like to ask if, generally, when using LVDS for transmission and reception, is it necessary to have a signal line to determine Enable?
- FvM
LVDS is an IO standard, not a transmission protocol. If you use a SPI like protocol, you'll have clock, enable and data lines. You can also use UART style asynchronous protocol with start/stop bits. Or synchronous protocol with sync pattern. A popular method is 8b/10b encoding, receive clock derived from data stream by CDR circuit.
- Scarlet
I can't believe it. Even though I added lvds_en for frame synchronization in the interface,
it still completes the reception on the rising edge of the 11th lvds_clk.
Below are my Verilog code and output results. What might I have overlooked?
module lvds_receiver ( input wire clk, input wire reset, input wire lvds_en, input wire lvds_clk, input wire lvds_data, output reg [11:0] data_out, output reg gpio_1, output reg gpio_2 ); reg [1:0] state; reg lvds_clk_prev; reg [3:0] loop = 4'h0; reg [11:0] data_reg = 0; parameter IDLE = 2'b00; parameter RX = 2'b01; parameter DONE = 2'b10; // lvds_clk_rising_edge wire lvds_clk_rising_edge = !lvds_clk_prev && lvds_clk; always @(posedge clk or negedge reset) begin if(!reset) begin state <= IDLE; end case(state) IDLE: begin if(!lvds_en) begin loop <= 4'd0; state <= RX; end end RX: begin lvds_clk_prev <= lvds_clk; // Check for rising edge of lvds_clk if (lvds_clk_rising_edge) begin data_reg <= {data_reg[10:0], lvds_data}; loop <= loop + 4'd1; gpio_2 <= ~gpio_2; end // When 12 bits are received, update data_out and reset loop if (loop == 12) begin gpio_1 <= ~gpio_1; state <= DONE; end end DONE: begin data_out <= data_reg; if(lvds_en) begin state <= IDLE; end end // default: state <= IDLE; endcase end endmodule - AqidAyman_Altera
We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
Please be assured that we are doing everything we can to resolve this issue as quickly as possible. However, this process will take some time, and we kindly ask for your patience and understanding during this period. The cases will be attended by AE shortly.
We appreciate your patience and understanding, and we are committed to providing you with the best support possible.
- AqidAyman_Altera
May I know are you still facing this issue?
Aqid
- AqidAyman_Altera
As we no longer receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
- Scarlet
Sorry for replying so late.
The issue has been resolved.
