11 years agoGood design, bad design -> one-clock-states in state-machines
another question is giong through my mind: Is it possible (good design) to create one or more states which exit to next state without any condition. example:
if (rising_edge(clock)) then
case (current_state) is
-- Idle State
when S000 =>
Signal_Data <= X"00";
Signal_Ctrl <='0';
sig_Start_IN <= Start_IN;
if ((sig_Start_IN = '0') AND (Start_IN = '1')) then
current_state <= S010;
else
current_state <= current_state;
end if;
-- State010
when S010 =>
Signal_Data <= X"34";
Signal_Ctrl <='0';
current_state <= S020;
-- State020
when S020 =>
Signal_Data <= X"F2";
Signal_Ctrl <='1';
current_state <= S000;
-- What else could be done?
when others =>
end case;
end if;
Is this a problem for synthesis? I never seen such a one-clock-state without condition in other codes before and therefore I don't know is it good or bad to do this. No one ever mentioned such states. What do you think? Save or unsave to do this? PS: I don't want a discussion about how much sense it makes to implement this or what it can be good for. I just want to know if this will work securely.8 Replies
you can do that, no problem. I have state machines many times like that to just cause one clock latency.
now it's safe.-------------------------------------------------------------------- -- State010 -------------------------------------------------------------------- when S010 => Signal_Data <= X"34"; Signal_Ctrl <='0'; current_state <= waitForMe ; -------------------------------------------------------------------- -- waitForMe -------------------------------------------------------------------- when waitForMe => Signal_Data <= X"34"; Signal_Ctrl <='0'; current_state <= S020; -------------------------------------------------------------------- -- State020 -------------------------------------------------------------------- - Altera_Forum
Often called wait states, for example using a state machine to read from a ram that has a few clocks of latency.
OK, thank you. So they are safe to use and the synthesis should understand them. Nice.
Ähmm, linas, what are you trying to tell me????? - Altera_Forum
As long as you stick to the templates, theres not a lot that is "unsafe" to use.
Aslong as you have: if rising_edge(clk) then as the first thing in the process, you can do pretty much anything inside it. - Altera_Forum
I added a wait state in your code. Nothing important happens there, just a delay of one clock cycle. One still needs to define control signals (Signal_Data and Signal_Ctr for this case) in this state, otherwise latches will be generated.
@linas: Ah, now I know. Thank you.
@tricky: Yes, this was an easy to learn lesson. Above all for me, I don't have to care about the sensitivity-list anymore ;) - Altera_Forum
--- Quote Start --- @linas: Ah, now I know. Thank you. @tricky: Yes, this was an easy to learn lesson. Above all for me, I don't have to care about the sensitivity-list anymore ;) --- Quote End --- If you are bothered by having to list all the input signals in a VHDL sensitivity list, you no longer have to do so. VHDL-2008 has a construct that automatically includes all inputs to a process, thus simplifying the sensitivity list. For example: //Old way my_old_process: process (A,B,my_reset, my_input) begin..... //New way. Just use the keyword "all" my_better_process: process(all) begin.... Robert lead trainer VHDL and Verilog www.digitaldesignconcepts.org
