FSK Modulation in VHDL
I have written a testbench which performs FSK modulation. The testbench should perform the auto checks such that when fsk_data_i(0) = '1' then I need to push fsk_u_i to fsk_mod_o whereas if fsk_data_i(0) = '0' then I need to push fsk_l_i to fsk_mod_o. But it is not doing so in my code. I don't know why. Also I am getting an error " Index 22 out of bound 21 downto 0". The tetbench code looks like this:stim_proc: process
begin
wait for 10 ns;
reset_n_i <='1';
wait for clk_128meg_i_period;
enable_i <='1';
--fsk_u_i <= "10001000"; -- 136
--fsk_l_i <= "11101000"; -- 232
--fsk_data_i <= "1111000010101010111010"; -- 3943098
new_fsk_u_s <= "10101010";
new_fsk_l_s <= "11110000";
new_fsk_data_s <= "1110101101010101010111";
wait for 1 ns;
new_fsk_u_s <= "10001000";
new_fsk_l_s <= "11101000";
new_fsk_data_s <= "1111000010101010111010";
wait for 10 ms;
reset_n_i <= '0';
wait for 1 ms;
reset_n_i <= '1';
wait for 1 ms;
enable_i <= '0';
wait for 1 ms;
enable_i <= '1';
wait for 1 ms;
assert false report "End of simulation" severity failure;
end process;
delay_rst_s <= reset_n_i after 1 ns;
p_check :process(delay_rst_s, clk_128meg_i)
begin
if (delay_rst_s = '0') then
clk_cycles_s <= (others => '0');
cnt_s <= (others => '0');
assert fsk_mod_o = "00000000" report " Output is not set to default value when reset_n_i is 0" severity error;
elsif (clk_128meg_i'event and clk_128meg_i = '0') then
if (enable_i = '1') then
clk_cycles_s <= std_logic_vector(unsigned(clk_cycles_s) + 1);
if (clk_cycles_s >= "1111111111") then
cnt_s <= std_logic_vector(unsigned(cnt_s) + 1);
if(fsk_data_i(to_integer(unsigned(cnt_s))) = '1') then
assert fsk_mod_o = std_logic_vector(fsk_u_i) report " Wrong output: fsk_u_i should be shifted " severity error;
elsif (fsk_data_i(to_integer(unsigned(cnt_s))) = '0') then
assert fsk_mod_o = std_logic_vector(fsk_l_i) report " Wrong output: fsk_l_i should be shifted " severity error;
end if;
end if;
else
cnt_s <= (others =>'0');
end if;
end if;
end process;
And the VHDL code is as follows: begin
p_fsk_mod : process(reset_n_i, clk_128meg_i)
begin
if (reset_n_i = '0') then
temp_s <= (others => '0');
cntdiv_s <= (others => '0');
elsif (clk_128meg_i'event and clk_128meg_i = '1') then
cntdiv_s <= std_logic_vector(unsigned(cntdiv_s) + 1); -- counter to count the clock cycles--
if (cntdiv_s >= "1111111111") then -- condition to check if the clock cycle is equal to 1023--
cnt_s <= std_logic_vector(unsigned(cnt_s) + 1); -- increment the "logik" block--
if (fsk_data_i(to_integer((unsigned(cnt_s)))) = '1') then -- shift the bits of fsk_data_i according to the value of the "logik" block--
temp_s <= std_logic_vector(fsk_u_i); -- perform the muliplexer operation based on the bits being pushed by the "logik" block--
else
temp_s <= std_logic_vector(fsk_l_i);
end if;
end if;
else
end if;
end if;
end process;
fsk_mod_o <= temp_s ;
I couldn't figure out what the mistake is. Can anyone help me out. Thanks in advance.10 Replies
'1' is std_logic, how come it passed compilation sorry my fault(it is index) - Altera_Forum
Yes it is index. Can you help to solve this problem
Your problem is difficult to read due to too much type conversion and lack of concept explanation and lack of full code
The issue of bit out of range should be obvious. your data is 22 bits yet the counter is exceeding 21 index. you need to account for that and constrain your counter. - Altera_Forum
Yes, but when I tried to constrain the counter still I am having the error. I will explain how the code works, maybe you will have an idea about it.
First of all, the clk_cycles_s is used to push each values of fsk_data_i, fsk_u_i and fsk_l_i after every 1023rd clock cycle because that's the main motive of my design. I am designing a PLL that needs to be clocked only after every 1023rd clock cycle. After the first 1023rd cycle(assume), new values of fsk_data_i, fsk_u_i and fsk_l_i has to be provided as per my code(sorry i didn't declare in my testbench, but checked only for a single values of all the above three, its working properly). Once all the 22 bits of fsk_data_i (since i have defined the bit width as 22), new values for fsk_data_i, fsk_u_i, fsk_l_i should be defined, which I don't know how to do. What I need exactly is, I need to change the inputs when all the 22 bits of the fsk_data_i are checked. I think so , you have understood the manner in which my code actually works. I need to help me to solve this issue - Altera_Forum
I just don't know why still I get the error " Index 22 out of bound 21 downto 0". Please help me out to solve this issue.
have a look at my changes (not tested), counters as integers (0 to 1023 & 0 to 21)
begin process(resetn, clk) begin if resetn = '0' then fsk_mod_o <= (others => '0'); cnt_s <= 0; cntdiv_s <= 0; elsif clk'event and clk = '1' then if enable = '1' then cntdiv_s <= cntdiv_s + 1; if cntdiv_s = 1023 then cntdiv_s <= 0; cnt_s <= cnt_s + 1; if cnt_s = 21 then cnt_s <= 0; end if; end if; if fsk_data_i(cnt_s) = '1' then fsk_mod_o <= std_logic_vector(fsk_u_i); else fsk_mod_o <= std_logic_vector(fsk_l_i); end if; end if; end if; end if; end process; - Altera_Forum
Thanks kaz, I got it , but i need to know like how to update new values of fsk_data/ u /l once all the values of fsk_data are checked
--- Quote Start --- Thanks kaz, I got it , but i need to know like how to update new values of fsk_data/ u /l once all the values of fsk_data are checked --- Quote End --- when clock count reaches 22*1024 a new value can be passed to your design - Altera_Forum
Instead of using the wait statement like wait for 22.5 us, is there any other way to implement it
I tried with the wait statement and its working well, but actually I need another method where within the module I can change the input values once all the bits of fsk_data_i are checked. Please help me to solve this issue. Thanks in advance
