alvertos
2 years agoFGPA quartus
i have this error what do i do? Internal Error: Sub-system: DYGR, File: /quartus/ddb/dygr/dygr_place_info.cpp, Line: 3776 Stack Trace: 0x43282: DYGR_ROUTE_TIMING_INFO::get_timing_node + 0xd6c2 0x...
_AK6DN_
2 years agoFirst (and this goes out to anyone submitting reports like this) is provide as much info as you can about
your system setup and what you were doing. Without that info few if any constructive comments can
be given. The first questions will always be your system config/version, quartus version, and device.
So what version of OS are you using? Be specific.
Version of quartus you stated, so good there.
What device are you compiling for?
Without any other info my only suggestion would be to do an uninstall/reinstall of Quartus and device support and retry.
FvM
2 years agoOne thing you should try before reinstalling Quartus is to delete the db folder of your design to achieve a clean recompile.
You should also try to recapitulate how you got there. Did compilation work before and started to fail after a certain step? Besides possible corruption of Quartus installation or design database, it can be also an erroneous or at least unsupported code construct.
