Cyclone 10GX Transceiver TX and RX independent
I am trying the cyclone 10gx low latency 10G base-R MAC example design(which comes with the duplex TX and RX mode)with the transceiver in TX and RX independent mode. When I try to merge the TX and RX with the following commands:
set_instance_assignment -name XCVR_RECONFIG_GROUP 1 -to rx_serial_data[1] -entity altera_eth_top
set_instance_assignment -name XCVR_RECONFIG_GROUP 1 -to tx_serial_data[1] -entity altera_eth_top
set_instance_assignment -name XCVR_RECONFIG_GROUP 0 -to tx_serial_data[0] -entity altera_eth_top
set_instance_assignment -name XCVR_RECONFIG_GROUP 0 -to rx_serial_data[0] -entity altera_eth_top
set_instance_assignment -name XCVR_RECONFIG_GROUP 0 -to altera_eth_top:altera_eth_top_inst|TX*twentynm_hssi_avmm_if_inst*
set_instance_assignment -name XCVR_RECONFIG_GROUP 0 -to "altera_eth_top:altera_eth_top_inst|RX*twentynm_hssi_avmm_if_inst*" -entity altera_eth_top
The project compiles but during hardware testing,the no of good packets as well as bad packets is zero. What has to be done to merge the TX and RX in this example design.
Sorry, I forgot to attach the designs in earlier post
- Deshi_Intel
HI,
Can you let me know which example design that you are referring here ?
- Any URL link to download the example design or how do you generate the example design ?
Also, I presume you are testing using C10 GX dev kit board or your own board ?
- Does the example design hardware test passed without modification on the qsf file setting ?
dlim
- Visshnu
i used the document from the link below and created the example design
https://www.intel.com/content/www/us/en/programmable/documentation/dbf1520991817584.html
The example used transceiver in duplex mode but i wanted to try tx and rx in simplex mode.i created a tx and rx ip separately using the same ip parameters and used it in the altera_eth_wrapper. I am trying to understand the working of the transceiver .
Yes i am using cyclone 10gx dev kit(10CX220YF780E5G) .The example design passed the hardware test without any modifications .
- Deshi_Intel
May I know why you want to break the duplex channel into simplex channel ?
Other than using the XCVR_RECONFIG_GROUP qsf command that you shown earlier, you also need to take care of the overlap address mapping. You can refer to below KDB link for more detail.
You may need to modify the example design accordingly to remap back correct address space. This could be one the of the reason that explained failure in your side.
dlim
- Visshnu
hi,
thanks for the kdb article ,I am currently trying to understand the working of the Transceiver and wanted to know how it would work if set in simplex mode. In the altera_eth_base_r_wrapper.v file i have set the tx and rx pins as
.reconfig_clk (csr_clk),
.reconfig_reset (~csr_rst_n),
.reconfig_write (phy_csr_write),
.reconfig_read (phy_csr_read),
.reconfig_address (phy_csr_address),
.reconfig_writedata (phy_csr_writedata),When i tried this the the same issue occurs .Is this the right way to do it or should i change it in the platform designer?
- Deshi_Intel
HI,
Did you change it in just your RTL design ?
I think it's better if you follow the KDB workaround guideline to modify the design in platform designer
- The goal is to merge the address space for both Tx and Rx together
dlim
- Visshnu
Hi ,
In the qsys file ,i have added the TX and RX ip files and an Avalon pipeline bridge ip. In the platform designer ,gave the same wire level expressions as in the KDB article .Now another issue occurs
Error(12829): Failed to merge HSSI Avalon Memory-Mapped interface instances "dut_inst|CHANNEL[0].wrapper_inst|u0|xcvr_native_a10_0|g_xcvr_native_insts[0].twentynm_xcvr_native_inst|twentynm_xcvr_native_inst|inst_twentynm_xcvr_avmm|avmm_atom_insts[0].twentynm_hssi_avmm_if_inst" and "dut_inst|CHANNEL[0].wrapper_inst|u1|xcvr_native_a10_0|g_xcvr_native_insts[0].twentynm_xcvr_native_inst|twentynm_xcvr_native_inst|inst_twentynm_xcvr_avmm|avmm_atom_insts[0].twentynm_hssi_avmm_if_inst" into single Avalon Memory-Mapped Interface.
Error(12829): Failed to merge HSSI Avalon Memory-Mapped interface instances "dut_inst|CHANNEL[1].wrapper_inst|u0|xcvr_native_a10_0|g_xcvr_native_insts[0].twentynm_xcvr_native_inst|twentynm_xcvr_native_inst|inst_twentynm_xcvr_avmm|avmm_atom_insts[0].twentynm_hssi_avmm_if_inst" and "dut_inst|CHANNEL[1].wrapper_inst|u1|xcvr_native_a10_0|g_xcvr_native_insts[0].twentynm_xcvr_native_inst|twentynm_xcvr_native_inst|inst_twentynm_xcvr_avmm|avmm_atom_insts[0].twentynm_hssi_avmm_if_inst" into single Avalon Memory-Mapped Interface.What is the workaround for this issue??
- Deshi_Intel
HI,
Let me try to check around to see if I can find example design to showcase to you how to merge simplex channel.
dlim
- Deshi_Intel
HI,
Also may I know which Quartus version that you used ?
Have you tried with at least v19.4 and onwards ?
Deshi
- Visshnu
I am using 20.2 version Quartus Pro edition .
- Deshi_Intel
Simplex channel merge design requirement
- Deshi_Intel
You can now compare and cross check with your design
- PVanL
Hi Deshi, i worked with Visshnu on this subject for his internship, and he is now proceeding to his masters. Unfortunately, we didn't ,manage to map your design including our PHY design, to the cyclone.
The simulation works though, with the xcvr_x1_plb_s0 (Avalon-MM interface, readdata, writedata etc...) signals unconnected. I don't understand what the purpose of those signals are: The tx_parallel [63:0] signal carries the to-be-send signal, the tx_tx_serial signal carries the serial output, whereas rx_rx_serial receives the incoming signal, and the rx_rx_parallel[63:0] carries the received parallel data...For what do you then need this Avalon-MM interface?
Also, i am not really sure what we mean with simplex. My interpretation is: There is a channel[0], on the end of which there is a trcvr[0] with a tx channel. That channel is connected via the 10Gbps cable to the rx-channel of the trcvr[1] in channel[1]. Simplex as: there is only one channel, carrying traffic in one direction. Of course not very useful in normal datacommuncation, but more simple, and using less LU's.
A duplex system would then be:
A: there is a channel[0], with a tx_trcvr[0], connected via the 10gbps cable to rx_trcvr[1] in channel[1], AND a channel[1] with tx_trcvr[1], connected via the same cable, but different pair, to the rx_trcvr[0], to channel[0],
OR:
B: there is a channel[0], with a tx_trcvr[0], connected via the FMC card to rx_trcvr[0] in channel[0]
Please advise,
regards, Pieter
