Cyclone 10GX Transceiver TX and RX independent
- 5 years ago
Sorry, I forgot to attach the designs in earlier post
HI,
Can you let me know which example design that you are referring here ?
- Any URL link to download the example design or how do you generate the example design ?
Also, I presume you are testing using C10 GX dev kit board or your own board ?
- Does the example design hardware test passed without modification on the qsf file setting ?
dlim
i used the document from the link below and created the example design
https://www.intel.com/content/www/us/en/programmable/documentation/dbf1520991817584.html
The example used transceiver in duplex mode but i wanted to try tx and rx in simplex mode.i created a tx and rx ip separately using the same ip parameters and used it in the altera_eth_wrapper. I am trying to understand the working of the transceiver .
Yes i am using cyclone 10gx dev kit(10CX220YF780E5G) .The example design passed the hardware test without any modifications .
