Cyclone 10GX Transceiver TX and RX independent
- 5 years ago
Sorry, I forgot to attach the designs in earlier post
HI,
Did you change it in just your RTL design ?
I think it's better if you follow the KDB workaround guideline to modify the design in platform designer
- The goal is to merge the address space for both Tx and Rx together
dlim
Hi ,
In the qsys file ,i have added the TX and RX ip files and an Avalon pipeline bridge ip. In the platform designer ,gave the same wire level expressions as in the KDB article .Now another issue occurs
Error(12829): Failed to merge HSSI Avalon Memory-Mapped interface instances "dut_inst|CHANNEL[0].wrapper_inst|u0|xcvr_native_a10_0|g_xcvr_native_insts[0].twentynm_xcvr_native_inst|twentynm_xcvr_native_inst|inst_twentynm_xcvr_avmm|avmm_atom_insts[0].twentynm_hssi_avmm_if_inst" and "dut_inst|CHANNEL[0].wrapper_inst|u1|xcvr_native_a10_0|g_xcvr_native_insts[0].twentynm_xcvr_native_inst|twentynm_xcvr_native_inst|inst_twentynm_xcvr_avmm|avmm_atom_insts[0].twentynm_hssi_avmm_if_inst" into single Avalon Memory-Mapped Interface.
Error(12829): Failed to merge HSSI Avalon Memory-Mapped interface instances "dut_inst|CHANNEL[1].wrapper_inst|u0|xcvr_native_a10_0|g_xcvr_native_insts[0].twentynm_xcvr_native_inst|twentynm_xcvr_native_inst|inst_twentynm_xcvr_avmm|avmm_atom_insts[0].twentynm_hssi_avmm_if_inst" and "dut_inst|CHANNEL[1].wrapper_inst|u1|xcvr_native_a10_0|g_xcvr_native_insts[0].twentynm_xcvr_native_inst|twentynm_xcvr_native_inst|inst_twentynm_xcvr_avmm|avmm_atom_insts[0].twentynm_hssi_avmm_if_inst" into single Avalon Memory-Mapped Interface.
What is the workaround for this issue??
