Signal Tap - *** Fatal Error: Segment Violation
I do not need help, after restarting Quartus I could proceed and the error did not occur again. Posting the problem report here in case it could be useful, see no other obvious place for this.
- KennyT_altera
May I know which Quartus version that you were using? What are the device that you are using? What OS that you were using?
Do you see this problem in multiple different project?
- KennyT_altera
Can attached the full error message here as well?
- cblixt1
It's all in the attached problem report, but it's Quartus Prime Pro 25.3/109 on Ubuntu 22. Maybe the device doesn't show up there, it is the Agilex 5 Premium Devkit, ES version. The problem report contains a stack trace which might be useful to find a bug, but the problem itself is not reproducible and I have not seen it before.
- KennyT_altera
Since it is not reproducible for now, can you update the report stack trace when it is duplicate from your side?
We shall close this temporally until you manage to duplicate it.
- KennyT_altera
We will close this for now, will address when the issue back.
