Visshnu
5 years agoCyclone 10GX Transceiver TX and RX independent
I am trying the cyclone 10gx low latency 10G base-R MAC example design(which comes with the duplex TX and RX mode)with the transceiver in TX and RX independent mode. When I try to merge the TX ...
- 5 years ago
Sorry, I forgot to attach the designs in earlier post
Deshi_Intel
5 years agoI created 2 example design based on above design requirement and it did pass fitter compilation
- Ensure both Tx simplex and Rx simplex reconfig interface connect to same design source
- Set both Tx and Rx pins to same Avalon MM group name
- My first example design is with "wire expression" connection in QSYS
- while my second example design is without " wire expression" connection in QSYS
Both designs are able to pass fitter compilation
dlim
Deshi_Intel
5 years agoSorry, I forgot to attach the designs in earlier post
