19 years ago
Counter between a data range(VHDL)
Hi, everyone.
This is the Counter I design, lines below:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity load_counter is
port( clk:in std_logic;
en:in std_logic;
data_out: out std_logic_vector(11 downto 0));
end entity;
architecture one of load_counter is
begin
process(clk,en)
variable temp:std_logic_vector(11 downto 0):="101100110110";
constant a1:std_logic_vector(11 downto 0):="010011001110";
begin
if en='1' then
if clk'event and clk='1' then
temp:=temp-1;
elsif temp=a1 then
temp:="010011001110";
end if;
end if;
data_out<=temp;
end process;
end one;
The error messages are:
Error (10818): Can't infer register for "temp[0]" at load_counter.vhd(18) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "temp[1]" at load_counter.vhd(18) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "temp[2]" at load_counter.vhd(18) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "temp[3]" at load_counter.vhd(18) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "temp[4]" at load_counter.vhd(18) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "temp[5]" at load_counter.vhd(18) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "temp[6]" at load_counter.vhd(18) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "temp[7]" at load_counter.vhd(18) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "temp[8]" at load_counter.vhd(18) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "temp[9]" at load_counter.vhd(18) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "temp[10]" at load_counter.vhd(18) because it does not hold its value outside the clock edge
Error (10818): Can't infer register for "temp[11]" at load_counter.vhd(18) because it does not hold its value outside the clock edge
Error (10822): HDL error at load_counter.vhd(18): couldn't implement registers for assignments on this clock edge
I mean to make it count between "010011001110" and "101100110110", but it doesn't work as I plan to.
I will appreciate it if anyone can give some help.
    I have solved the problerm.
    The vhdl lines should be these.
    begin
    process(clk,en)
    begin
    if en='1' then
    if temp>a1 then
    temp:=temp-1;
    elsif temp=a1 then
    temp:="101100110110";
    end if;
    end if;
    end if;
    data_out<=temp;
    end process;
    end one;
    hi, i am experiencing a simillar problem with all the error messages are the bottm, i do not see how this code solves the problem, could you offer me some guidance please,
    regards,
    Zadok
    Simply, the counter reload must be done within in the clock edge sensitive block. otherwise the construct isn't synthesizable.
    i sorted that out by adding a counter to my statements but i got 700 warnings of the kind below when i compiled my schematic.
    Warning: No clock transition on "db2_rom4:inst30|r_data[1]" register due to stuck clock or clock enable
    Warning: Reduced register "db2_rom4:inst30|r_data[1]" with stuck clock port to stuck value GND
    most of the code in my blocks looks like this
    entity db2_rom1 is
    port(r_clk : in std_logic;--clock input at the user data frequency
    r_data : out std_logic_vector (9 downto 0)--wavelet data vector representing a portion of the wavelet
    end db2_rom1;
    architecture daze of db2_rom1 is
    type mem is array (0 TO 9) of std_logic_vector (9 downto 0);
    constant rom : mem :=(
    0 => "0000000100",
    1 => "0000000111",
    2 => "1111101011",
    3 => "0000011100",
    4 => "1110110100",
    5 => "1111101011",
    6 => "0011000011",
    7 => "1110110100",
    8 => "1110011000",
    9 => "0000111011"
    begin
    process(r_clk)
    variable count : integer :=0;--defining a counter
    begin
    if rising_edge(r_clk) then
    r_data<=rom(count);
    count:=count+1;
    if count=10 then --check whether the ROM addresses have been exceeded
    count:=0;
    end if;
    end if;
    end process;
    end daze;
    With Quartus 5.1 , no warnings and errors.
    What analysis and synthesis soft do you use?
    It works for me in Modelsim. I would guess that the clock is the problem
    --- Quote Start ---
    --- Quote End ---
    To me this warning says that quartus knows that there isn't a clock signal going into the block. The reason could be that there is an enable signal that is always held to zero or that you've connected the wrong clock signal to the block or something else of that kind. I would focus on that before the code.
    If you can't find anything wrong with the clocks you could try to use a mega wizards ROM instead.
    Ola Bångdahl
    --- Quote Start ---
    i'm using quartus II 7.1
    --- Quote End ---
    Hi zadok,
    I tried your code (which you posted ) with QuartusII 8.0 and I got not warning regarding clock transitions. Could post your schematic ?
    Hapyang, your clock is probably getting messed up as you have the enable and clock the wrong way round. Try:
    begin
    process(clk)
    begin
         if en='1' then
              if temp>a1 then
                temp:=temp-1;
            elsif temp=a1 then
            end if;
        end if;
    end if;
    data_out<=temp;
    end process;
    end one;
