17 years agoi sorted that out by adding a counter to my statements but i got 700 warnings of the kind below when i compiled my schematic.
Warning: No clock transition on "db2_rom4:inst30|r_data[1]" register due to stuck clock or clock enable Warning: Reduced register "db2_rom4:inst30|r_data[1]" with stuck clock port to stuck value GND -------------------- most of the code in my blocks looks like this entity db2_rom1 is port(r_clk : in std_logic;--clock input at the user data frequency r_data : out std_logic_vector (9 downto 0)--wavelet data vector representing a portion of the wavelet ); end db2_rom1; architecture daze of db2_rom1 is type mem is array (0 TO 9) of std_logic_vector (9 downto 0); constant rom : mem :=( 0 => "0000000100", 1 => "0000000111", 2 => "1111101011", 3 => "0000011100", 4 => "1110110100", 5 => "1111101011", 6 => "0011000011", 7 => "1110110100", 8 => "1110011000", 9 => "0000111011" ); begin process(r_clk) variable count : integer :=0;--defining a counter begin if rising_edge(r_clk) then r_data<=rom(count); count:=count+1; if count=10 then --check whether the ROM addresses have been exceeded count:=0; end if; end if; end process; end daze;
