Altera_ForumHonored Contributor18 years agoCounter between a data range(VHDL) Hi, everyone. This is the Counter I design, lines below: library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; entity load_counter is port( clk:in std_logic; ...Show More
Recent DiscussionsQuartus Lite 23.1 MAX 10 EncryptionHow to fix Error(23782): Failed to find an expected reportSolvedMailbox Client IP - SEND_CERTIFICATE command through FPGA fabricQuartus Prime license rehosted, unable to runFailed to run ip-setup-simulation:
