18 years agoI have solved the problerm.
The vhdl lines should be these. architecture one of load_counter is begin process(clk,en) variable temp:std_logic_vector(11 downto 0):="101100110110"; constant a1:std_logic_vector(11 downto 0):="010011001110"; begin if en='1' then if clk'event and clk='1' then if temp>a1 then temp:=temp-1; elsif temp=a1 then temp:="101100110110"; end if; end if; end if; data_out<=temp; end process; end one;
